WAAS Edge Problem
Aug 1st, 2008
I am carrying out some test on WAAS for a client,every configuration seems okay.
The Edge WAE is stuck on the offline state,though i have done cms enable on the edge WAE,and network connectivity is ok-i can ping and even telnet to it,it can also ping both the central manager and the Core WAE.
What could be the problem,any other additional configurations that i should put in to resolve this.
Please help.
Rodrigo Marchin... Fri, 08/01/2008 - 04:36
In the Central Manager:
- To activate all inactive WAEs, click the "Activate all Inactive WAEs" icon.
- Select Create a new location for each inactive WAE, then click Submit.
- Click the Devices tab, then click Refresh Table Icon to verify that all of the WAEs are online. You may have to wait a few minutes before the status change to "Active". Click Refresh Table several times until becomes Active.
