cisco secure pix 525 configs not working
Aug 1st, 2008
Good day all,
I installed a pix 525 between my lan and the service provider. I have done the basic configurations but i can get to my inside port from the lan. please find attached the running configs. Please i need help.
Obinna
Overall Rating: 5 (1 ratings)
richnam Fri, 08/01/2008 - 03:07
hi,
Thanks for the reply. Yeah i used public IPs for the inside port because there is a server in the LAN that is doing nating. So, does that mean that this will only work with private IP addresses? Also i'll prefer to configure PAT instead of NAT on the PIX if need be. I have only one IP address on the WAN network.
Obinna
dhananjoy chowdhury Fri, 08/01/2008 - 03:56
Suppose this is the scenario,
Outside - 217.117.6.177 - interface e0
inside LAN - 10.0.0.0/24 - interface e1
Default gateway IP - 217.117.6.178
then configuration steps would be something like this...
for Outside interface :
interface e0
nameif Outside
security-level 0
ip address 217.117.6.177 255.255.255.248
for inside interface :
interface e1
nameif inside
security-level 100
ip address 10.0.0.1 255.255.255.0
for doing the PAT (with the outside interface IP :
nat (inside) 5 0 0
global (outside) 5 interface
for the default route:
route outside 0 0 217.117.6.178
richnam Fri, 08/01/2008 - 12:05
Thanks alot.
I'm gonna give it a try and get back to you on the result
Thanks one more time
Obinna
