ASA with anyconnect DTLS but no Compression
Aug 1st, 2008
the anyconnect client 2.2x is able to connect to an ASA (8.03) with TLS or DTLS. However, connecting via DTLS, it looks like that the compression is not working.
Simply disabling DTLS and reestablish a svc session with protocol TLS, the compression does work properly.
Any ideas, why this don't work. Could't find any specific documentation on this.
Any hint on this?
Cheers
Neil Cudmore Fri, 01/24/2014 - 02:09
Got the same problem here with 9.1(3) and using AnyConnect 3.0.5080, DTLS and RSA_AES_128_SHA1 cipher
I tried setting the compression on globally with
(config)# compression svc
But when connected client still shows Compression as none.
sirianthe3rd Thu, 07/17/2014 - 13:31
"compression svc"
Then under your AnyConnect group-policy:
webvpn
 anyconnect dtls compression lzs
Disconnect and reconnect the client.
