VPLS support on 10 gig 6704 module core
anasubra_2
Hi All,
Does VPLS is supported ,if the core links are in 10 gig 6704 module MPLS enabled ?
Any assistance on this would be really appreciated .
Anantha Subramanian Natarajan
67xx modules does not support VPLS core facing
According to my knowledge ES20, ES40 and SIP-600 are the only bords supporting VPLS
Jon
Hi Jon,
Thank you very much ........Is there any workaround to deploy VPLS over these core interfaces ?
hi Jon!
Even core-facing SIP-400 supports VPLS.(starting from the SXH release)
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/6500series/76ovwsip.html#wp1062432
Niranjan
