Egress Access-List logging
WE moved to a 4500 series core switch(Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(31)SGA6, RELEASE SOFTWARE (fc2).
We pasted in our old ACL's and got this message on the Egress ACL.
"The log keyword is not supported on ACLs attached to egress ports on this platform."
WE use the logging to see what ports are being blocked so we can open them up when a user needs them. Now I can't see any hits because it is not logging to my syslog box. All other ACL's log but the egress. Help.
rkhalil Sun, 08/03/2008 - 19:29
Why you use SYSLOG for this ?
Configure errdisable recovery...
SW(config)#errdisable recovery cause all 60
show the status..
SW#sh errdisable recovery
ErrDisable Reason Timer Status
udld Disabled
bpduguard Disabled
security-violatio Disabled
channel-misconfig Disabled
vmps Disabled
pagp-flap Disabled
dtp-flap Disabled
link-flap Disabled
l2ptguard Disabled
psecure-violation Disabled
gbic-invalid Disabled
dhcp-rate-limit Disabled
unicast-flood Disabled
storm-control Disabled
arp-inspection Disabled
loopback Disabled
Timer interval: 300 seconds
Interfaces that will be enabled at the next timeout:
