2950 Monitoring IP : not pingable and not managable ;(
Aug 1st, 2008
Hello Everyone
I changed last month my center-switch with brand new 3750
Nice boxes ..; no problem with the upgrade.
Pas de problemes pendant la migration.
Got to add an 2950 to add some more VLAN12 posts.
Configured as the other 2950 i already have here that worked fine ....
Trunk to the 3750s on GE 1 & 2.
Heres the 2950 config (nothing very complicated)
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Switch06
enable secret xxxx
enable password xxxx
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 12
switchport mode access
spanning-tree portfast
SNIP (every FE port are configured the same from 1 to 24)
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan15
ip address 10.21.5.6 255.255.255.0
no ip route-cache
ip default-gateway 10.21.5.254
no ip http server
line con 0
line vty 0 4
password xxxx
login
line vty 5 15
password xxxx
login
end
All my admins posts here are on VLAN 15
I monitor all the switch from theses...
No problem so far but that one just don't answer .... No ping no telnet...
Hmmm tried the shutdown/No shutdown trick ....
Switch06#conf term
Enter configuration commands, one per line. End with CNTL/Z.
Switch06(config)#interface vlan 15
Switch06(config-if)#shutdown
03:01:50: %LINK-5-CHANGED: Interface Vlan15, changed state to administratively d
own
Switch06(config-if)#no shutdown
03:02:02: %LINK-3-UPDOWN: Interface Vlan15, changed state to down
Switch06(config-if)#exit
Switch06(config)#exit
Switch06#
03:02:09: %SYS-5-CONFIG_I: Configured from console by console
changed state to down ????
I don't know why the VLAn is down ....
Tried to erase vlan config and rebuild from scratch ... Seems to be up but won't ping or manage... Sometimes at least it pings itself ....
Any clue ?
Config on the 3750 for that switch :
interface GigabitEthernet1/0/9
description Switch6 A
interface GigabitEthernet2/0/9
description Switch6 B
garytayl Fri, 08/01/2008 - 08:08
  • Silver, 250 points or more
Make sure that under show vlan, vlan 15 is listed if yes, then try to add one port to vlan 15 if you haven't done that yet
Richard Burts Fri, 08/01/2008 - 08:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jaboeuf
I believe that the issue is that there are no ports in vlan 15. All of the physical ports are assigned to VLAN 12 and no ports are in VLAN 15. One of the things that will bring a VLAN up is to have at least one active port.
The other thing that should bring a VLAN up is to have an active trunk. I wonder if there is some issue with the trunk between the switches. Can you show the status of the trunk?
Rick
