FWM - Suporte LLC2
Aug 1st, 2008
Hi all
Does FWModule/6500 control LLC2 traffic using ACL ?
Syed Iftekhar Ahmed Fri, 08/01/2008 - 09:42
From the FWSM config guide
An EtherType ACE controls any EtherType identified by a 16-bit hexadecimal number.
EtherType access lists support Ethernet V2 frames.
802.3-formatted frames are not handled by the access list because they use a length field as opposed to a type field.
BPDUs, which are handled by the access list, are the only exception: they are SNAP-encapsulated, and the FWSM is designed to specifically handle BPDUs. "
Syed Iftekhar Ahmed
