vpn client connected to ASA but cannot do anything after connected.HELP!
Aug 1st, 2008
I am struggled with this for last three days. I have a very basic case. My client wants to connect to my ASA using Cisco VPN client and connect to one host in my network ( This VPN configuration works and let me connect using Cisco VPN client. but I cannot go anywhere else after connected.
I cannot PING from client and cannot run any protocols (telnet, ftp etc.) to my host (192.,168.1.51). BUT I can run these protocols while I am on the inside network without VPN.
I verify the route exists in my core router (
“Ip route”
ASA Inside IP:
Core Router IP:
Server on the inside:
“Sysopt permit-ipsec” is enabled so that all VPN traffic bypass ACL on outside interface.
ASA 7.21 version
hostname ABC
interface Ethernet0/0
nameif outside
security-level 0
ip address
interface Ethernet0/1
nameif inside
security-level 100
ip address
#ACL 101 is used to bypass NAT
access-list 101 extended permit ip host
access-list aclout extended permit udp any interface outside eq 5008
#ACL 102 is for split-tunneling
access-list 102 extended permit ip
ip local pool testpool
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1
static (inside,outside) udp interface 5008 5008 netmask
access-group aclout in interface outside
route outside 1
route inside 1
group-policy mypolicy internal
group-policy mypolicy attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value 102
crypto ipsec transform-set SprintVPN esp-3des esp-sha-hmac
crypto dynamic-map dyn1 1 set transform-set SprintVPN
crypto map Mymap 1 ipsec-isakmp dynamic dyn1
crypto map Mymap interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 20
crypto isakmp ipsec-over-tcp port 10000
tunnel-group mytunnelgroup type ipsec-ra
tunnel-group mytunnelgroup general-attributes
address-pool testpool
default-group-policy mypolicy
tunnel-group mytunnelgroup ipsec-attributes
pre-shared-key *
isakmp ikev1-user-authentication none  This is used to disabled user authentication for VPN client.
acomiskey Fri, 08/01/2008 - 07:25
Your split tunnel acl is backwards.
