Autonomous AP to LWAPP
Aug 1st, 2008
I'm trying to migrate an Autonomous 1131-AP to LWAPP but when i try to prepare the infrastructure to do it pings from AP to WLC (to mngmt interface and to ap-mngmt int) just work for the first minute after the WLC is turning on and after that pings doesn't response. Everything (AP, WLC both interfaces and PC) is on the same subnet
Any idea of what's going on??
Scott Fella Fri, 08/01/2008 - 13:23
What model wlc and what code? Something is configured wrong... since it would be the easiest to have everything in one subnet. Are you using the tool to convert or WCS.... need more info.
macepeda.plannet Fri, 08/01/2008 - 15:47
Hi, thanks for your response fella5 i really appreciate it, but i already done it, do you wanna know what was it??
First i used a switch to get pings working and after that i typed "aaa new-model" global configuration command in the AP. All this besides the normal procedure.
See u in my next doubt!! =)
Trending Topics - Security & Network
