Erase DN in Call Manager
Aug 1st, 2008
We have CCM 6.1.0 and I set up a device with DN 8262. I deleted the device from Call Manager but need to delete the DN 8262. Where do you do this please?
Overall Rating: 5 (1 ratings)
david.macias Fri, 08/01/2008 - 08:58
  • Blue, 1500 points or more
The DN should be gone as well since you deleted the phone associated to it.
david
Jaime Valencia Fri, 08/01/2008 - 09:00
  • Cisco Employee,
  • Hall of Fame,
    2011
David, that is not correct. Starting from CUCM 4.1 DNs are not completely erased when you delete a device.
you need to go to the route plan report, select unassigned DNs and delete them from there. think of it as a recycle bin
java
if this helps, please rate
Mojo1 Fri, 08/01/2008 - 09:09
Yes you are correct the Route Plan Report is exactly what I was looking for.
When I call the number now I get a busy signal even though is is deleted. I assigned the DN to a Digital Phone and you can call the the extension from digital phones but when you try to call from an ip phone you get a busy signal.
david.macias Fri, 08/01/2008 - 09:33
wow, this is a big change and I had no idea... tells you how much time I spend in the UCM. thank you for the education.
david
