Syslog just Stops
Aug 1st, 2008
I continue to have problem with syslog. I have to delete my subscripition on Ciscowork and restrat cisco before it starts displaying recieved syslog msg. But this only last for a day or two and then it hangs again. When I go to syslog I see when i recieved the last msg. My server is still running, I can process other jobs but recieve no syslog msgs.
Any one experience this?
Mike
Joe Clarke Fri, 08/01/2008 - 09:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You need to enable SyslogCollector debugging in Collector.properties. Then restart SyslogCollector. When the messages stop getting processed, check the SyslogCollector.log for errors. This may not be the location of the problem, but it's a good place to start.
Note: I am assuming that when this problem happens, the messages are still being delivered to the syslog log file on the server. If not, then perhaps you have a network problem.
michael.m.williams Fri, 08/01/2008 - 10:34
I can't locate where I enable syslog collector debug. I went to both RME and CS.
Mike
Joe Clarke Fri, 08/01/2008 - 10:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This needs to be set in NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/classes/com/cisco/nm/rmeng/csc/data/Collector.properties.
