Creating IPM collector causes SUP to fail
Joe Clarke Fri, 08/01/2008 - 12:04
As akemp pointed out, you may be seeing a bug. Was there anything in show logg or on the console like a trace back? It could help confirm this diagnosis.
yjdabear Fri, 08/01/2008 - 14:21
If you mean the switch reloads, this is probably because of CSCsd36155 (also listed as CSCin62031) in the 12.2(18)SXF# code you're running: "IOS crashes when SNMP is used to activate an IP SLA Probe.
This bug effectively means you can't use IPM to configure IP SLA collectors on devices running the affected versions. It leaves you the option of having to configure the collectors on the IOS CLI manually.
