Passed Authentication Logs on ACS 4113 SE appliance
Aug 1st, 2008
I need to get a copy of all Passed Authentication logs from our appliance. Is there a way that I can ftp all those files to another device? Or is there another way that I can retrieve those files?
Jagdeep Gambhir Sat, 08/02/2008 - 06:21
Yes, you can send logs to another system on the network using remote agent.
Remote Logging for ACS SE with ACS Remote Agents
The Remote Logging feature enables ACS to send data to one or more ACS Remote Agents. The remote agent runs on a computer on your network. It writes the data that ACS sends to it into CSV files. You can configure many ACS Solution Engines to point to a single remote agent, thus making the computer that runs the remote agent a central logging server.
For more information about installing and configuring an ACS Remote Agent, see Installation and Configuration Guide for Cisco Secure ACS Remote Agents Release 4.1
Do rate helpful posts
