2950 abnormal loop reboot
Aug 1st, 2008
We are having a huge issue on our 2950. We are using Cisco IP telephony but when we upgrade the phones, some cat 2950 switch start to reboot in loop. The only workaround we found is to remove all cable to make the switch start normally. But when we plug a plug it reboot again!!
Does someone can help me
C2950 12.1(22)EA4a
Thx
Luc
Mark Yeates Fri, 08/01/2008 - 17:37
  • Gold, 750 points or more
Luc,
I would try upgrading the IOS on your switch. It appears to be a bug that is causing the switch to crash. The latest version for this switch is 12.1(22)EA12.
Mark
