How to determine the management IP of the CatOS
Aug 1st, 2008
hi guys,
i dont know if its the right term for finding the management ip address of the CatOS. im on the MSFC of the 6509 and i want to find out the ip address of the CatOS so that i can create vlan under this 6509.is there any command ?
tnx
jeff
Overall Rating: 5 (1 ratings)
Marwan ALshawi Sat, 08/02/2008 - 00:05
if u r on the MSFC config mode
just type end
then
exit
u should go to the switch
on the switch typ
show config
u should see an interface configured with ip address called sc0 this is what r u looking for
please, if helpful rate
jeffersoncbriones Sat, 08/02/2008 - 01:22
actually im on the router mode and i dont know the ip address of the switch. can i see the ip address of the switch on the router mode ?
tia
Marwan ALshawi Sat, 08/02/2008 - 03:25
is it the os is CAT OS or IOS?
as i told u if it is CATOS and u r on the MSFC
u should only typ exit exit then u gonna go to the switch config mode
there u can view th configuration by the comman
show config
if u see interface named sc0 with ip address thats for managment
Richard Burts Sat, 08/02/2008 - 08:10
Jeff
If you are on the router side I would expect that show cdp neighbor would show the switch as a cdp neighbor. And if that is the case then show cdp neighbor detail should show the IP address for management of the switch.
Rick
jeffersoncbriones Mon, 08/04/2008 - 17:28
Hi guys,
I hope im not sending the wrong info here. i have 6509 cat switch. i have only access to the router part of it, my question is how can i access the ip address of the catOS inside this 6509. Do i need to this catOS or i can directly create vlan on the router mode?
tia
Marwan ALshawi Mon, 08/04/2008 - 18:41
because it is cat OS
u need to creat the VLAN on the switch then go to the MSFS to creat the VLAN interface also known as SVI
on the swith do:
set vlan {vlans} [name name] [type type] [state state] [said said] [mtu mtu]
[bridge bridge_num] [mode bridge_mode] [stp stp_type] [translation vlan_num]
[aremaxhop hopcount] [pvlan-type pvlan_type] [mistp-instance mistp_instance]
[ring hex_ring_number] [decring decimal_ring_number] [parent vlan_num]
[backupcrf {off | on}] [stemaxhop hopcount] [rspan]
then do for example from the switch mode session 15
u will go to the MSFC
then on the MSFC do :
interface vlan 10
ip address 10.1.1.1 255.255.255.0
no shut
the config above only example
Richard Burts Mon, 08/04/2008 - 19:07
Marwan
Jeff has told us more than once that he has access to the MSFC but not to the switch. Therefore your advice about what he should change on the switch is not useful.
Jeff
Perhaps it would help us to give you better advice if you could give us some more detail about your situation. How is it that you have access to the MSFC (the router part) but not to the switch?
Have you attempted my suggestion about show cdp neighbor detail? Does the MSFC see the switch as a neighbor?
If for some reason the MSFC does not see the switch as a neighbor then are there any other Cisco devices connected to any of the switch ports? If so, then show cdp neighbor might show the IP of the switch on those devices.
Rick
Marwan ALshawi Mon, 08/04/2008 - 19:19
Richard
to be honest i got lost
because i wanna guid him but we look like in the same stage till now
i just given him the above info
because he asked that dose he need to go to the switch mode or not??
so i told him because u are useing CATOS u have to creat the L2 vlan on the switch mode then
make the SVIs on the MSFC
am i right Mr. Richard ?
and this is jeff Q:
" Do i need to this catOS or i can directly create vlan on the router mode? "
and good luck for jeff
jeffersoncbriones Mon, 08/04/2008 - 22:06
Hi Rick,
show cdp will not pull out the ip address.
Before im handling some 6500 switches wherein i have a management ip address for the switch and also for the router part.
Right now i have the ip address of the router part and im asking if i can get the ip address of the switch part (sc0 maybe).
Sorry creating some heat. And thanks for all your help, each posts gains me knowledge.
Tnx
