Block P2P Traffic and Bittorrent
Aug 1st, 2008
Hi, I am looking a solution to block all P2P and bittorrent traffic by ASA FW (8.03 ver) and allow only a single machine in the network which is not to be blocked by ASA. Please suggest...
Overall Rating: 5 (1 ratings)
nikuhappy2010 Sat, 08/02/2008 - 00:46
Can anyone show here the configuration step by step?? Thanks!!!
nikuhappy2010 Sat, 08/02/2008 - 01:14
Hi, the example is for P2P and IM Traffic Configuration and i wana block only P2P traffic. Question:- Does Bittorrent use P2P protocol?? Is there any free proxy server would you recommand through which I cud filter the same traffic instead of doing configuration on ASA. Thanks!!!
dhananjoy chowdhury Sat, 08/02/2008 - 01:33
  • Silver, 250 points or more
If you go thorugh the config statements in th example, you will see different sections for IM and P2P.
Just ignore the statements for IM and use the rest for P2P.
Regarding your query for Proxy Server to block P2P, there are may products which claim that but I don't know how efective they are. Some are listed here.
http://www.exefind.com/block-p2p/
nikuhappy2010 Sat, 08/02/2008 - 06:33
By this example for P2P traffic blocking, it will be valid for all softwares which works on P2P prrotocol. And what about Bit torrent traffic, will the traffic be also blocked? I am so confused in this...Please suggest..
