VOIP QOS over GRE ISSUE
Aug 2nd, 2008
Hi All,
I have this problem with VOIP phone calls been very poor, and need to fix it ASAP.
I have a stalite link between the Head office and Branch site.
Head office is cisco 3845 and Branch is cisco 3825.
And the Phone system is NEC ( with IP Trunk) via the GRE tunnel.
I have a GRE Tunnel between the sites since the IP address I am using on the LAN are Not supported by the sat Provider.
Can you please have a look on the attched and advice if I am missing any thing.
I have configured a QOS setting and applyied it to the tunnel interface per the following Cisco guide
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a008017405e.shtml
but the QOS polices are not Matching the NEC PBX traffic.
Thanks for your help
Nour
Marwan ALshawi Sat, 08/02/2008 - 05:24
do u know what is the default marking of that traffic i mean the NEC?
what is the matching crateria u follow to match the NEC PBX traffic ?
