08-02-2008 04:37 AM - edited 03-15-2019 12:22 PM
A customer has asked me to setup toll-bypass with no authentication. For some reason when the call is sent to the outgoing pots dial-peer, its sends call out PRI instead of presented dial-tone and allowing caller to enter desired digits.
Called number 0402222 comes in over the wan to gateway and matches below incoming voip dial-peer
dial-peer voice 20 voip
description INCOMING DIAL PEER
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
And it matches outgoing POTS dial-peer below
dial-peer voice 10 pots
destination-pattern 0402222
port 0/0/0:23
Debug ISDN q932 reveals calls is sent to telco (no called number obviosly) and call fails. What I want is when it hits this outgoing dial-peer, dial-tone is presented to caller and they can enter digits and then be sent out PRI.
Any ideas on what can be wrong? Why call is sent out PRI instead of dialtone?
Thanks in advance,
08-02-2008 05:58 AM
Has Cisco remove the security hole so now even if you don't have direct-inward-dial statement on POTS dial-peer, you can't get secondary dial-tone?
08-03-2008 02:04 AM
try to add another dial-peer in addition to what u have
dial-peer voice 11 pots
direct-inward-dial
port 0/0/0:23
OR do the fowlloing
dial-peer voice 12 pots
answer-address .T
port 0/0/0:23
