DHCP Server config on 2960G, 3560G and 3550 switches
Aug 2nd, 2008
Im using 2 x 3750G switches as callapsed core/distribution switches. I have 6 Vlans (1, 10,20,30,40,50) that will be assigned per switch block.
Switch block 1
This will have 5 switches in the block connected at the top switch via fibre trunk to core_1 and at the bottom switch via fibre trunk to core_2. Each switch is then daisy chained, via copper, to one and other and all switches in the stack have vlan 10 assigned to there ports. Vlan 1 also has access as it is the management vlan and all servers are configured on this vlan.
All the other switch blocks are connected the same as above but have a different Vlans configured and some have less switches in the stack.
I have a selection of switches mainly 6+ x 3560G's, but also 3550G, 3550 and 5 x 2960G's.
I'm looking at configuring a DHCP server on the top switch on each switch block/stack, to assign IP address to clients on the assigned vlan eg Vlan 10 - network.
I have been trying to configure DHCP on a 2960G Lanbase switch but cannot get it to assign an ip to a laptop I plug in to it.
I have reset the config now but was trying:
ip dhcp pool Vlan10
default-router (ip of vlan 1 on core_1)
option 150 ip (not sure why? read a sample config)
dns-server ***.***.***.****
(again do not have dns-server configured and connected to the network, just 1 x laptop, 2x cores and 2 x 2960G's)
I assigned an IP address pool and created excluded-addresses, but still I have problems!! :0(
Can someone please help me with the config as I'm struggling? , also if the configuration would be better on one of the other model of switches I have eg. 3560G etc then please give your opinion?
Many thanks
Marwan ALshawi Sat, 08/02/2008 - 07:27
u have to creat the required VLAN(s)
then for each VLAN u have to Creat a DHCP config the relate to that vlan and havs the right ip subnet
lets say u have vlan 10
make the vlan on ur access layer switch
with command
vlan 10 [enter]
name vlan_10
then assign this vlan to the required ports
and make sure the switch port no shutdown anslo the is Important thing which is the spanning tree PORTFAST this otion if u dont put it on access port for client need DHCP u gonna loss the DHCP
for example
interface range fa0/1 - 24
switchport mode access
switchport access vlan 10
spanning-tree portfast
no shut
these ports ready to connect the PCs
now next step for distribution layer and DHCP
make the connection between the access switches and the Dist switches trunk to pass VLAN tags
then on the Dist switches creat the same vlans numbers
and creat for each vlan a switched virtual interface SVI which will be the defaul gateway for client in the corspoding VLAN
example Dist switch
vlan 10
vlan name vlan_10
interface vlan 10
ip address
no shut will be the default gateway for vlan 10 users
then go to configure the dhcp on the switch
note: if u have the dhcp on other router, switch or server u have to add th ip hlper command on the SVI interface poiting to that dhcp server
in our example the Dist switch will be the dhcp so we dont need that command
ip dhcp pool vlan10
about option 150 this option used when u have IP telphoney and voice vlan to point to the TFTP server
if u dont have u dont need it
and repeat the same config for each vlan but with deffrent ip address
for example dhcp for vlan 20
shoud like
ip dhcp pool vlan20
default-router 20..1.1.1
and so on
dont for get the SVI
and the access port config with portfast
being enable
also check the dhcp service if enabled or not(by default yes)
this link also helpful
good luck
please, Rate if helpful
