VLAN trunk problem
Aug 2nd, 2008
I have three switches connected in series, I see the following on the middle switch and there is no traffic flow...
I have tried turning off pruning but I cannot get traffic to flow over interface g6/0/1...can anyone help?
LDA-LNK-AccSwch02>sh int g6/0/1 tru
Port Mode Encapsulation Status Native vlan
Gi6/0/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi6/0/1 50
Port Vlans allowed and active in management domain
Gi6/0/1 none
Port Vlans in spanning tree forwarding state and not pruned
Gi6/0/1 none
LDA-LNK-AccSwch02>
Overall Rating: 2 (1 ratings)
sundar.palaniappan Sat, 08/02/2008 - 13:24
  • Green, 3000 points or more
Does VLAN 50 show as active in the 'show vlan' output?
Is VLAN 50 allowed on the trunk port on the other switch?
What model switch is this? Some of the low end catalyst switches have a limitation on how many VLANs they can support.
lamav Sat, 08/02/2008 - 13:31
  • Blue, 1500 points or more
Sundar makes a good point that is oftentimes missed.
If the vlan is not configured on the switch, traffic from that vlan will not traverse that trunk, even though it's allowed.
So, as SUndar said, lets see the o/p of a "sh vlan"
VL
davegibelli Sat, 08/02/2008 - 13:36
Sundar
All three 3750 switches have vlan 50 active, there is a maximum of 5 vlans on any switch
50 BLG-Data active Fa1/0/11
50 BLG-Data active
50 BLG-Data active
davegibelli Sat, 08/02/2008 - 13:41
SW1-----------------SW2---------SW3
int vl 50--------------no svi------int vl 50
ip 10.167.50.3--------------------ip 10.167.50.1
sw2 can ping 10.167.50.3 only
sw3 can ping 10.167.50.1 only
sundar.palaniappan Sat, 08/02/2008 - 13:52
Can you provide the following output from all 3 switches?
show int trunk
show vlan
show vtp status
davegibelli Sun, 08/03/2008 - 05:47
Sundar
I have provided the output for you...I am going crazy with this as I just cannot see waht is wrong...starting to suspect ios bug!
Giuseppe Larosa Sun, 08/03/2008 - 03:11
  • Hall of Fame,
    Founding Member
Hello Dave,
take care to verify if vlan 50 exists at Layer 2,
do
conf t
vlan 50
exit
then redo sh vlan id 50
Because from your output is clear that vlan 50 doesn't exist at layer 2 (may be you created an interface vlan 50 but that is another object that exists at L3 )
>>>>Gi6/0/1 50
>>>Gi6/0/1 none
>>>Gi6/0/1 none
only vlans in STP forwarding state really travels on the trunk
Hope to help
Giuseppe
r.waterman Sun, 08/03/2008 - 06:53
Dave
out of interest can you also display the results from:
sh span vlan 50 sum
I suspect that the trunk interfaces from SW2 to SW1 to SW3 may be in a blocking state, but the above command will identify the stp status of those trunk links.
davegibelli Sun, 08/03/2008 - 11:42
Well I suspected an IOS bug....have a look at the output of sh span vl 50 sum for SW2 in the attachment!!!
I removed VLAN 50 on SW1 (VTP server) and immediately added it back and everything works as it should
Yet another IOS bug obviously :)
Giuseppe Larosa Mon, 08/04/2008 - 09:25
  • Hall of Fame,
    Founding Member
hello Dave:
interesting issue.
note that there is a mismatch on the type of STP you are running on your switches:
SW3>sh span vl 50 sum
Switch is in pvst mode
SW1>sh spann vl 50 sum
Switch is in rapid-pvst mode
SW2>sh span vlan 50 sum
I would suggest to have the same type of STP on all switches even if RPVST is backward compatible
Hope to help
Giuseppe
