Cisco Unity Express Failed
Aug 2nd, 2008
I upgraded my CUE to version 3.2 and after it stated all successful I rebooted the service module and now it constantly says that it has failed. I tried to reload and keep getting this status.
SC-RTR#service-module service-Engine 0/1 statu
Service Module is Cisco Service-Engine0/1
Service Module supports session via TTY line 258
Service Module is trying to recover from reset/shutdown
Service Module heartbeat-reset is enabled
Service Module status is not available
Is there any other way to try and recover the module
jbarcena Thu, 08/07/2008 - 06:54
Reloading the router should have fixed the problem... but if you have tried that perhaps you coulds try unplugin the router leave it for a minute and then plug it back...
david.vanherck Wed, 04/29/2009 - 04:07
Thanks for the info! My CUE was stuck in a loop after I tried to do a clean install. After unplugging it, leaving it for a minutes aside and re-insert it and now I can reinstall the soft :-)
chadlincoln Wed, 04/29/2009 - 05:25
When you reload the router by the reload command, it doesn't power down/reload the CUE module. To reload the CUE module, put in:
service-module integrated-Service-Engine 0/0 reset
Where the 0/0 is the slot your CUE module is in.
Please rate if this helps.
