Access only few Internet websites URL
Answered Question
Aug 2nd, 2008
Hi, I want to block the usage of internet for Inside users except few websites. Please advice.
The QA testing team test some application by connecting remote servers which is connected by STS Tunnel. And I have opened IP protocol between both Sites and they test the application which is using a port 80. Here, I would say that the network must not be blocked if we make any rule for Inside Users.
Correct Answer by Marwan ALshawi about 8 years 7 months ago
Vinay
u can block and make filtering on the application layer through MPF as with Rate limiting
but this gonna be a bit more comlicated as u have to make some regular expretion and more class-maps
i will guid u through it bellow:
first u wanna allow only the spesified websites and any other websites will be blocked!
lets say u gonna allow youtube.com and yahoo.com and any other websites should be blcked
first creat regular expretion to match those URLS
regex URLLIST1 "\.yahoo\.com"
regex URLLIST2 "\.youtube\.com"
then creat ACL matching web traffic
access-list 101 permit ip any any eq www
access-list 101 permit ip any any eq https
access-list 101 permit ip any any eq 8080
class-map web-traffic
match access-list 101
creat class-map for the regex created above(URLLIST)
class-map type regex match-any allowed-sites
match regex URLLIST1
match regex URLLIST2
now creat inspection class map for web traffic matched with class above
class-map type inspect http match-all blocking-urls
match not request header host regex class allowed-sites
notce there is not in the comman here this mean match any thing except the urls we have match above
so we are exculding the match URLs and bellow we gonna mak a policy and the action we gona tak is drop
creat http inspection policy
policy-map type inspect http block_URLS
class blocking-urls
reset log
now if u look above we creat ACL 101 that match web traffic and match with class-map called webtraffic
now we gonna apply the above http inspection policy to that traffic
policy-map inside-policy
class webtraffic
now apply it to ur inside interface
service-policy inside-policy interface inside
good luck
please, rate if helpful
Overall Rating: 5 (2 ratings)
Correct Answer
Marwan ALshawi Sun, 08/03/2008 - 07:14
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
Vinay
class blocking-urls
reset log
class webtraffic
good luck
Marwan ALshawi Sun, 08/03/2008 - 18:21
i think the config that i have sent do exactly the same thing in those files
anyway good luck
nikuhappy2010 Sun, 08/03/2008 - 20:46
Hi, I have installed a proxy server and blocked all inside traffic (Inbound) and exempt tunnel traffic as well in inside access list and its working fine. Now I want that all inside users mail, IM,(For all users) Yahoo Messanger (Selected Machines) traffic to be allow from inside to outside. Mail Smtp port is 995 and Pop3 port is 465 and both are using SSL. Please suggest what do i need to do for the same. Please post an example, if possible. Thanks
Marwan ALshawi Sun, 08/03/2008 - 21:48
nikuhappy2010 Mon, 08/04/2008 - 02:05
Hi, Thanks for the above links....But my query was for allowing the ports which is 465 and 995 and works on SSL (pop.gmail.com, smtp.gmail.com. I wud want that inside users e-mail traffic to be allow by inside interface (inbound) to outside. Please suggest..
I am using the proxy server and all internet traffic are going through proxy but I want that IM, Yahoo Messanger (Selected Machines) and E-mail (All Inside Machines) traffic forward to outide internet by Inside Interface instead of using proxy. Thanks
nikuhappy2010 Mon, 08/04/2008 - 02:36
Well, the e-mail settings cud configure on Proxy server but if i do then users e-mail works very slow and IM, skype and yahoo we use basicaly we use for voice based calls and through proxy it doesnt work properly.
Then all user machines should have a default gateway of the primary layer 3 device or ASA inside interface.
All I.E/Firefox brower settings should be proxied thru the proxy server.
IM should be not be configured for proxy.
This is not fool proof, anyone with any network knowledge will be able to bypass this.
nikuhappy2010 Mon, 08/04/2008 - 04:49
Then all user machines should have a default gateway of the primary layer 3 device or ASA inside interface. (Thats right)
All I.E/Firefox brower settings should be proxied thru the proxy server. (Yes)
IM should be not be configured for proxy. (Yes nd traffic will be bypass through default gateway through inside interface of ASA)
(Well I know its possible but I am bit confused how i have to do setting for SSL encryted trafic for e-mail ports of 465 and 995).
Please suggest
nikuhappy2010 Mon, 08/04/2008 - 05:35
Well just tell me that how i can allow the internal machines traffic to outside for IM, Yahoo Messanger and E-mail (Using Ports 995 and 465 used for G-mail) except all deny traffic. I dont know which of the ports get used for this. Please suggest.
Marwan ALshawi Mon, 08/04/2008 - 05:40
i think u need a policy map
any way can u tell me what is ur topology
if u can post simpl graph will be better
i wanna know how u route ur traffic to the proxy
nikuhappy2010 Mon, 08/04/2008 - 05:51
ASA Conf:-
Inside :- 192.168.12.1
Outside :- *.*.43.210
Default Gateway set on all Client machines :- 192.168.12.1
Proxy Server :- 192.168.12.20
Please suggest..
Marwan ALshawi Mon, 08/04/2008 - 07:39
then
how u route clients traffic to the porxy?
it looks like the traffic going only to the asa
nikuhappy2010 Mon, 08/04/2008 - 07:51
I have denied all inside (inbound) traffic except Proxy machine traffic. Users send their request directly to proxy for using Internet but I want all e-mail, IM, Yahoo Messanger traffic to be allow by inside interface thats why i set up this IP 192.168.12.1 for gateway in client machines. Not able to understand how to do this??
Marwan ALshawi Mon, 08/04/2008 - 08:13
ok
there is two way to configure firewall with proxy
first
make the users default gateway proxy ip address
then the proxy should have cashing and filtring rules to filter ur traffic after that the proxy shout be made to forward the traffic to the ASA in this case the default gateway of the proxy is th einside interface of the ASA
withing the above methed u can make the defaul gateway the ASA for clients that u dont want them to go through the proxy
bypass it
second methond ( it hink better)
is to make another interface
on the ASA DMZ interface
and put the proxy server there
make a route on the ASA to route the traffic to the proxy on the dmz
and in this case the users default gateway will be the ASA inside ip
then the ASA will forward the traffic back to the ASA after filter it
and u can control who to be sent to the firewall or not
inur case i meanwhat u have configured
u can mkae ACL that pemirt users IPs going to certainports
but with IM hard becuase they use deffrent ports even 80 tunneled in http
i sent u link before relate to block IM use and make the ACL match users u wants and make it permit for them
through policy map and inspection should be better, becuase u gonna fillter on application layer
good luck
rate if helpful
nikuhappy2010 Mon, 08/04/2008 - 08:29
Hi, thanks for your prompt response.
I can use the first method and set the client machines DG of proxy server then users e-mail traffic wud go in this way. Client----Proxy----Inside ASA----Outside.If I use this then e-mails downloading get works so slow thats why I want to set the proxy settings in the IE so that when users open any site then the request to be forward proxy server and e-mail, IM, Yahoo Messanger Traffic to be forward directly inside interface and by making access list the inside interface cud allow these three app traffic except all other traffic.
Marwan ALshawi Mon, 08/04/2008 - 17:18
ok allow smtp and pop3 from those client
and about IM
i told u read the link i sen u u can achive it through
policy-map type inspect im im_pmap_name
Firewall(config-pmap)# match [not] ip-address
ip_address subnet_mask
Firewall(config-pmap-c)# {drop-connection | reset}
Match: Client IP address
Action: Drop or reset the
connection
Firewall(config-pmap)# match [not] login-name regex
{regex | class regex_cmap_name}
Match: Client's IM login
name
connection
Firewall(config-pmap)# match [not] protocol
[msn-im] [yahoo-im]
Match: IM protocol
connection
Firewall(config-pmap)# match [not] service {chat |
conference | file-transfer | games | voice-chat |
webcam}
Match: IM service
connection
Firewall(config-pmap)# match [not] version regex
Match: IM file transfer
service version
connection
good luck
please, Rate if helpful
