AP1100 WGB
Aug 3rd, 2008
Trying to connect AP100 in WGB mode to a Qwest AP with WEP KEY. Using Doc ID: 68472 as reference. The radio shows down and not sure how to trouble shoot?
Any help would be great..
Thanks Matt
amritpatek Fri, 08/08/2008 - 14:39
By default, the SSID of the Workgroup Bridge is tsunami, and it tries to acquire an IP address over the wireless link through DHCP. Wired Equivalent Privacy (WEP) is off by default. If an IP address is already configured, you might make a Telnet connection or browse to that IP address. These default settings apply to a 350 series WGB that run the firmware version 8.89.
You can also reset the WGB to factory defaults, with the use of a paper clip on the small reset hole, and then use the default address in order to access it if DHCP fails.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
