sip call over flow
Aug 3rd, 2008
I configure the as5400 with two dial peers (1st and 2nd) for provider A and two dial peers (3rd and 4th) for provider B. Both of them offer sip calls.
If 1st dial peer for provider A is not working, I would like the call flow to 2nd dial per to provider A.
If 3rd dial peer for provider B is not working, I would like the call flow to 4th dial per to provider B.
How do I configure it? any sample configuration?
rdgs
anitachoi3 Mon, 08/04/2008 - 07:56
I add it but the call will not flow to second dial-peer when first dial-peer not working. Below is my config
R1
dial-peer voice 6501 voip
description provider A
tone ringback alert-no-PI
service session
destination-pattern 65.
no huntstop
max-conn 108
session protocol sipv2
session target ipv4:192.168.12.32
dtmf-relay rtp-nte h245-signal h245-alphanumeric
dial-peer voice 6502 voip
service session
pref 1
no huntstop
max-conn 108
session target ipv4:205.x.x.x
dial-peer voice 4401 voip
description provider B
service session
destination-pattern 44.
no huntstop
max-conn 108
session target ipv4:192.168.24.32
dial-peer voice 4402 voip
service session
pref 1
no huntstop
session target ipv4:134.x.x.x
If I shutdown the 1st and 3rd dial-peer
, the call can flow to next dial-peer. How do I config the overflow automatically?
rdgs
noc-au Mon, 08/04/2008 - 17:37
ok, you have to specify the hunt by putting this command: dial-peer hunt ( 0-7)
anitachoi3 Tue, 08/05/2008 - 05:16
Sorry that I do not have any idea regarding "dial-peer hunt ( 0-7)"? what "0-7" refer to? please advise
rdgs
noc-au Tue, 08/05/2008 - 21:35
the 0-7 mean the following:
0 - Longest match in phone number, explicit preference, random selection.
1 - Longest match in phone number, explicit preference, least recent use.
2 - Explicit preference, longest match in phone number, random selection.
3 - Explicit preference, longest match in phone number, least recent use.
4 - Least recent use, longest match in phone number, explicit preference.
5 - Least recent use, explicit preference, longest match in phone number.
6 - Random selection.
7 - Least recent use.
anitachoi3 Wed, 08/06/2008 - 08:11
I should add below command:
R1
dial-peer hunt 2
I would like the call hunt to next dial-peer "only if" the first dial-peer is down (not working). Other conditon e.g. busy, no answer, wrong number.... , it keeps on going to the first dial-peer.
base on above requirment, any missing?
rdgs
anitachoi3 Sat, 08/09/2008 - 00:34
I configure
dial-peer hunt 2
to router and find that all calls get busy if the first dial-peer is shutdown.
anything I missing?
rdgs
