CISCO ACS
Aug 3rd, 2008
Hi All
I am new to the CISCO ACS software ,at present our vpn clients are being authenticated using the cisco acs
My problem is when they get connected they are being assigned with a subnet mask and gateway can any one help me to find out where it is configured and how can it be changed .
NOTE :- there is no radius attribute IETF configured on the acs
lgijssel Sun, 08/03/2008 - 21:17
  • Red, 2250 points or more
VPN users do not necessarily receive their ip address and mask etc via radius. This may very well be performed by an ip pool on the vpn device. In that case, only the authentication would be done via ACS.
What device are you using?
Can you post the config?
regards,
Leo
muralee29477 Sun, 08/03/2008 - 21:23
hi leo
tks a lot for your reply ,
ok also how is the gateway ip is decided for the client
please reply
Farrukh Haroon Sun, 08/03/2008 - 23:18
What is ure VPN termination device? ASA, VPNC, IOS Router?
Farrukh
muralee29477 Mon, 08/04/2008 - 00:23
hi I am sorry for the wrong info
it is terminating on Pix 515
Farrukh Haroon Mon, 08/04/2008 - 00:47
Can you post the output of
show run vpn-addr-assign
If your Firewall is running 7.x
Farrukh
