use two broadband sources?
Aug 3rd, 2008
Cisco 2561XM router
Can a 2651XM router take advantage of two available broadband sources and use them both at the same time? The obvious point of this would be to double my broadband speed. I have one broadband source through a wic-adsl card and another through the Fastethernwt0/1 port. My lan is on Fastethernet0/0. Thanks for any advice.
exonetinf1nity Sat, 09/27/2008 - 11:46
I think what your referring too is bonding which Cisco Routers cant do, you can use routing though to put certain traffic types down different links or as mentioned above load balance the connections
