Use aaa new-model
jolo07310
Level 5
Level 5
We use windows 2003 IAS and try to configure aaa new-model for authenticate to Cisco router and switch.
We have no problem at switch, but cant make it work at router with same configuration:
Here is the configuration:
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius local
radius-server host 10.x.x.100 auth-port 1645 acct-port 1646 key pass
radius-server host 10.x.x.101 auth-port 1645 acct-port 1646 key pass
I apply same config at the router, but doesn't, which I have no clue why.
Ken
Farrukh Haroon
It seems you have a space after your shared secret as in 'pass ' no both lines, try to reenter the command without the space, then use the 'test aaa' command to verify this. If you go to the IAS server logs, you might find a shared secret mismatch.
Farrukh
