port forward from adsl to PC
Answered Question
Aug 3rd, 2008
I'm struggling to set up a port forward in a cisco 2600 router.
My internet comes in through a wic-adsl card, it is configured with no ip address. My dialer0 config gets the ip address from my isp (eg aa.bb.ccc.ddd). My LAN connects to f0/0 which is set at 172.16.1.30. My PC is set at 172.16.1.15 and I need to forward a port number to this PC.
I tried 'ip nat inside source static tcp..etc in the dialer0 interface but I got
router(config-if)#ip nat inside source static tcp ....
% Invalid input detected at '^' marker.
router(config-if)#
I've seen 'ip nat inside source static ' in cisco documents but I don't understand why I'm getting an error when I do it.
Thanks for any pointers.
Correct Answer by rkhalil about 8 years 8 months ago
not apply the ip nat inside command in the interface configuration mode.
put the command in global router configuration
Example:
router# conf t
router(config)# ip nat inside source static 171.16.68.5 x.x.x.x
Overall Rating: 5 (1 ratings)
Correct Answer
rkhalil Sun, 08/03/2008 - 17:36
  • Bronze, 100 points or more
Example:
router# conf t
tonyspcrepairs Mon, 08/04/2008 - 10:01
thankyou for your help rkhalil, I was now successful in setting up the ports.
