CISCO IPCC EXPRESS FEATURES AND PRODUCT SPECIFICATIONS
Answered Question
Aug 3rd, 2008
Does anyone know,what does this term mean:
- Capture and Process Caller DTMF Input
- Automated Attendant Support
- Database Integration
- Automatic Speech Recognition
- Text to Speech
- Real-Time Notification Services (Email, Paging, Fax)
- Voice XML for ASR/TTS and DTMF
- Read data from HTTP and XML pages
- Run any Defined Workflow via HTTP Request
- Integrated Self-Service Application Support
I got it from Cisco technical reference for IPCC Express 4.0 product. Is there any explanation for user?
Correct Answer by Chris Deren about 8 years 11 months ago
Be able to recognize telephone DTMF key presses and contract logic, such as redirect a call based on entered digits, basically IVR functionallity.
Configure Auto Attendant, where a user can call into a company and enter someones extension or name and be transfered to the person.
Integrate IPCC to extername DB for date input/read, i.e. lookup someone's account balance based on account number
Be able to recongnize speech and route the call based on the word/phrase
- Text to Speech
Covert text to speech, i.e. read the account balance to the caller over the phone
Based on an event generate an email, etc
Advanced custom voice XML coding for Speech recognition and/or Text to speech funtionallity, basically advanced IVR funtionallity
Similarly to db integration, you can develop xml and http processing
You can construct a script to allow callers to be self serviced, i.e. call in and check account balance, transfer funds to another account, etc.
Basically IPCC Express is a powerful ACD/IVR/CTI application capable of all the above traditional features.
HTH, please rate all useful posts!
Chris
Overall Rating: 5 (1 ratings)
Chris Deren Sun, 08/03/2008 - 20:13
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Which term are you referring to?
These are features of IPCC Express Premim edition, and they are pretty self explenatory, which one do you need more explenation for?
Chris
sovannary.huy Sun, 08/03/2008 - 20:30
The term I refer to all the features, like "Process Caller DTMF Input", what does it mean? "Voice XML for ASR/TTS and DTMF" what does it mean? or what it do?
Correct Answer
Chris Deren Sun, 08/03/2008 - 20:39
  • Hall of Fame,
- Text to Speech
Chris
