RAID-5 critical error
Aug 3rd, 2008
I have 7371 which had disk00 failure. I reloaded the WAE during week end. Now I do not see the disk00 failure.. But I see RAID-5 critical when I do 'show disk details'. Everything looks normal. But does any one know how to get rid of RAID-5 critical error ?
sachinga.hcl Mon, 08/04/2008 - 18:17
you must run a script (the WAAS disk check tool) that checks the file system for errors that may result from a RAID synchronization failure.
You may obtain the WAAS disk check tool from the following URL:
http://www.cisco.com/pcgi-bin/tablebuild.pl/waas40
When you run the WAAS disk check tool, you will be logged out of the device. The device automatically reboots after it has completed checking the file system. Because this operation results in a reboot, we recommend that you perform this operation after normal business hours.
To run the WAAS disk check tool, follow these steps:
Step 1 Copy the script to your WAE device by using the copy ftp disk command.
WAE# copy ftp disk disk_check.sh
Step 2 Run the script from the CLI, as shown in the following example:
WAE# script execute disk_check.sh
This script will check if there is any file system issue on the attached disks
Activating the script will result in:
Stopping all services. This will log you out.
Perform file system check for few minutes.
and record the result in the following files:
/local1/disk_status.txt - result summary
/local1/disk_check_log.txt - detailed log
System reboot
If the system doesn't reboot in 10 minutes, please re-login and check the result files.
Continue?[yes/no] yes
Please disk_status.txt after reboot for result summary
umount: /state: device is busy
umount: /local/lPAM_unix[26162]: ### pam_unix: pam_sm_close_session (su) session closed
for user root
waitpid returns error: No child processes
No child alive.
Step 3 After the device reboots and you log in, locate and open the following two files to view the file system status:
•disk_status.txt- Lists each file system and shows if it is "OK," or if it contains an error that requires attention.
•disk_check_log.txt-Contains a detailed log for each file system checked.
If no repair is needed, then each file system will be listed as "OK," as shown in the following example:
WAE# type disk_status.txt
Thu Feb 1 00:40:01 UTC 2007
device /dev/md1 (/swstore) is OK
device /dev/md0 (/sw) is OK
device /dev/md2 (/state) is OK
device /dev/md6 (/local/local1/spool) is OK
device /dev/md5 (/local/local1) is OK
device /dev/md4 (/disk00-04) is OK
Step 4 If a file system contains errors, follow the instructions in the disk_status.txt file to repair the file system.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v4013/release/notes/ws4013rn.html#wp272874
kindly send the out of the following command :
show disks details
can read this section.
Might be it give you some relevant information regading your case.
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v4013/configuration/guide/maint.html#wp1144150
Kind regards,
Sachin garg
rhegde Tue, 08/05/2008 - 09:04
Thanks for the reply.. This is how the show disk details look..
ACC#sh disk det
RAID Physical disk information:
disk00: Online J8VU2HYC 286102 MB
disk01: Online J8VV6E5C 286102 MB
disk02: Online J8VU2D0C 286102 MB
disk03: Online J8VV6EVC 286102 MB
disk04: Online J8VU27LC 286102 MB
disk05: Online J8VU2E1C 286102 MB
RAID Logical drive information:
Drive 1: RAID-5 Critical
Enabled (read-cache) Enabled (write-back)
Mounted file systems:
MOUNT POINT TYPE DEVICE SIZE INUSE FREE USE%
/sw internal /dev/sda1 991MB 615MB 376MB 62%
/swstore internal /dev/sda2 991MB 281MB 710MB 28%
/state internal /dev/sda3 7935MB 190MB 7745MB 2%
/local/local1 SYSFS /dev/sda7 55548MB 953MB 54595MB 1%
/disk00-05 CONTENT /dev/sda6 1289499MB 1105872MB 183627MB 85%
.../local1/spool PRINTSPOOL /dev/sda8 991MB 16MB 975MB 1%
Disk encryption feature is disabled.
Oddly CM GUI shows only disk00 enabled when you look at the Monitoring--> Disks but WAE CLI lists all the disks.
We opened a TAC case on this and TAC engineer suggested , it may be due to bad disk and suggested us to replace it. This is being one of the core data center, we have scheduled the disk replacement during the week end..
Zach Seils Tue, 08/05/2008 - 20:56
RAVEENDRA,
You want to check the output of 'sh disk tech' and see if "PFA" is set to 'Yes' for any of the drives. If so, replace the drive.
Zach
rhegde Wed, 08/06/2008 - 08:53
Hello Zach,
When I do 'sh disk tech' and I see all the disks but none of them are set with PFA is set to YES. I see RAID critical. But on CM GUI, I see only disk00 is enabled as shown in my attached doc.. Can you take a look ??
ravi
Zach Seils Mon, 08/11/2008 - 15:16
I need to take a look at more detailed system information. Can you please unicast me a sysreport from the device?
Zach
