UCM:Can it possible to add new field in Corporate Directory
Aug 3rd, 2008
Running UCM 6.1.2 cluster.
Presently in IP Phone for searching the user,user uses
Directories>Corporate Directory
In Corporate Directory option user will get below details:
First Name:
Last Name:
Number:
Can it possible to add additional field apart from above; like field name called " Initial"
(one more field to the Corporate Directory).
And what about the End user configuration in CallManager?because we need to add
one more addtion fileld which user can able to search the user through new added fileld.
Please let me know.
Thanks & Regards,
espereir Mon, 08/04/2008 - 02:16
  • Silver, 250 points or more
Hello Krishnamurthy,
This is one of the questions that have been asked a lot; unfortunately, we cannot modify the directory nor the Directory pages on CUCM 6.X. However, you can use an external directory application but you will need a developer; if you have someone that could help you programming the new directory, go to the Developer Central site and download the IP Phone SDK, there you will find detailed instructions on how to create a custom directory. The IP Phone SDK contains a directory example. Again, we cannot modify the CCM code / database, but we can create another directory service but will need to get help from a programmer.
Here is the Developer Support Central site:
http://www.cisco.com/en/US/products/svcs/ps3034/ps5408/ps5418/serv_home.html
Hope this helps!
