Permit ICMP from inside interface to Outside Interface
Answered Question
Aug 3rd, 2008
Friends, i have ASA 5520. I opened pop3 and smtp port for mail. But, from outside network (internet) when i type my ASA's public IP address in the pop3 and smtp mail works fine. But inside in my network in this case mail is not working. ISP staff told me that inside host should ping ASA's outside IP but i can not PING...
My task is next: Inside host should access mail using ASA Public IP address in POP3 and SMTP field
Correct Answer by Marwan ALshawi about 8 years 11 months ago
first about ping
in ASA u cant ping ASA interface from another interface even if u enable icmp inspection u will be able to pass icmp but not ping interface from another interface!!
so if u have access to ur network dont worry about this ping issue
secondly r u using static nat for ur mail server?
and if the users in the network reside in the same interface to the mail server why udont us its private IP for those users
for example if the server ip is 10.10.10.1
put this ip for inside users
also some time esmtp insspection make problems try to disable it
good luck
if helpful rate please
Overall Rating: 5 (1 ratings)
dhananjoy chowdhury Sun, 08/03/2008 - 23:00
  • Silver, 250 points or more
Try this...
policy-map global_policy
class inspection_default
inspect icmp
Correct Answer
Marwan ALshawi Sun, 08/03/2008 - 23:03
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
first about ping
good luck
batumibatumi Sun, 08/03/2008 - 23:16
I'm using ASDM and in the servic policy i mark ICMP in the default inspection. To tell you true to disabl ESMTP did not try yet.
P.S. Yes, as you said to write down mail's server inside IP mail works fine, but my users every day go out and POP3 is important for me.
