Schedule WLC to on/off AP
Aug 3rd, 2008
Just want to check with you. Can we asked WLC to schedule down or up for the AP. For example, during office hour we will up the wireless. When the time is over, WLC will down the AP.
ericgarnel Mon, 08/04/2008 - 06:11
I played around with this a bit. here are the details.
You need 2 files, the script and the variables file. Anyone who has ever used mrat will feel right at home with this setup. You will need expect on the server
NOTE: I am not the author, but I have left his info intact for credit
File1: the command file
====== cut below this line ===============
#Info: Peter Kok(
output=$($path_to_scriptsdir/wlc.exp $router $username $password)
associated=$(echo $output|grep -o Associated|wc -l)
probing=$(echo $output|grep -o Probing|wc -l)
authenticated=$(echo $output|grep -o Yes|wc -l)
echo -n "asso_clients:$associated prob_clients:$probing auth_clients:$authenticated "
exit 0
=== end cut ===========
File2: the variables
set router [ lindex $argv 0]
set username [ lindex $argv 1]
set password [ lindex $argv 2]
spawn ssh $router
set timeout 10
expect "(yes/no)?" {
send "yes\r"; exp_continue }
expect "User:"
send -- "$username\r"
expect "password:"
send -- "$password\r"
expect "Controller)"
send -- "show client summary\ry\ry\r"
expect "Controller"
send "logout\r"
expect "(y/N)"
send -- "n\r"
expect eof
You can see on line 21 where to place the command you desire, and yes, you will need to keep the syntax at the end.
Forgot to mention: Once you have the script built, you can call it via cron at the desired times
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
