Split tunnel / Local LAN access
astanislaus
Level 2
Level 2
What troubleshooting steps can we performed if Anyconnect Client is unable to access the Local LAN after establishing a tunnel to the ASA. Pointers to any troubleshooting URLS much appreciated.
astanislaus
Level 2
Level 2
Any Connect version 2.1
Marwan ALshawi
check ur split tunneling ACL
check the netbios server and dns if u are using
also make sure that have created NAT exmption also called NAT 0
with the comman
nat (inside) 0 access-list 100
where access-list 100
is an access-list matching traffic from ur LAN to the anyconnect van client pool
for example if u lan 192.168.1.0/24
and ur pool with 10.1.1.0/24
make it as follow
access-list 100 permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.0
and apply it to the nat examption (nat 0 ) as i have done above
good luck
please, if helpful Rate
