Nating Problem- Need clarification
Aug 4th, 2008
Hi I configured natting for the dmz server to access from inside interface...
let say my dmz server ip is and configure a local natted ip as after i enabled the natting i am not able to access the server using dmz ip( but i can able to access through I am using ASA5510. In the pix firewall 525, the same configuration works well...i mean that i can access both the nated ip and dmz ip as well... I want to know that this feature disabled in ASA...? .Pls advise..thanks
Jigar Dave Mon, 08/04/2008 - 01:51
Hi Hajasheriff,
please It will be beneficial to understand if you provide actual command executed on ASA as well as PIX,
Farrukh Haroon Mon, 08/04/2008 - 09:03
From which zone are you trying to access the IPs? Also can you give more details about your setup. There is no such difference between the ASA and PIX, this is definitely a configuration issue.
