Multiple SSIDS with VLAN ACL seperation
Aug 4th, 2008
I have bought a 887W and I'm new to wireless on a router, I need advice about seperating multiple SSIDs with access list.
I have configured 2 SSIDs one for 'trusted' clients and one for 'guest' clients. I want to prevent the 'guest' SSID obtaining access to the other vlan/SSID using an ACL.
Each SSID is associated with a BVI, the BVI has the IP address, then it's linked to a seperated VLAN interface, then each VLAN.
Thanks if you can help...
Dave
davidjbradley Tue, 08/05/2008 - 23:19
Solved my issue, I simply attached the ACLs to the BVI interfaces. Fairly obvious, but I read a Cisco webpage that said this could not be done, although this may have been a temporary bug that has been fixed.
