cme - media negotiation fails
Aug 4th, 2008
I'm doing SIP trunking with the german voice provider QSC. You can find the config and the version data below. In some points it works fine, but dialing in from somewhere else (e.g. mobile) than from a fixed line of the Deutsche Telekom doesn't work. I get messages and errors about failed media negotiation. But I can't see any difference in the INVITE message as compared to successful calls. Can you please tell me what goes wrong and how to fix it? Attached are files with debugs (messages, media, error) of both the unsuccessful and the successful communication, and an on-the-wire trace of the unsuccessful communication. Thanks.
Cisco 2811 (revision 53.50)
Cisco IOS Software, 2800 Software (C2800NM-IPVOICEK9-M), Version 12.4(20)T, RELEASE SOFTWARE (fc3)
voice service voip
allow-connections sip to sip
registrar server expires max 600 min 60
voice register global
mode cme
source-address port 5060
max-dn 144
max-pool 42
load 7960-7940 P0S3-08-9-00
authenticate register
timezone 23
time-format 24
date-format D/M/Y
bulk 062211879000
tftp-path flash:
file text
create profile sync 0253240513247794
network-locale DE
user-locale DE
ntp-server mode unicast
voice register dn 1
number 062211879000
voice register pool 1
id mac 0003.6B8B.1700
type 7960
number 1 dn 1
username username password password
no call-waiting
voice translation-rule 1
rule 5 /^[1-9]\(.*\)/ /06221&\1/
voice translation-rule 2
rule 5 /9.../ /062211879000/
voice translation-profile outward
translate calling 2
translate called 1
voice-card 0
no dspfarm
dial-peer voice 10 voip
translation-profile outgoing outward
destination-pattern .T
session protocol sipv2
session target sip-server
keepalive target
authentication username username password 7 password realm
timers keepalive active 300
registrar expires 3600
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
pcameron Mon, 08/04/2008 - 04:52
This problem is likely due to codec interworking between the external SIP device and the version of IOS on the router. The call is getting rejected due to a codec mismatch. Since you do not have any 'incoming called-number' statement, the router would use the default dial peer which specifies G729.
There is a reasonably well known issue involving codec interworking that is due to Cisco defect CSCeh19375.
This DDTS was not specifically a bug, but it added IOS compliance for RFC 3555. RFC 3555 changes the way G729 is dealt with - the parameter "annexb" must be included in the SDP. In this case, the parameter is not included in the SDP from the SIP proxy and as a result, the router will try and use G729br8. This codec is not configured and the call fails.
As a fix, try adding G729br8 codec to a voice class codec and binding this to dial peer 10 by means of the command 'incoming called-number .'
voice class codec 1
codec preference 1 g729br8
codec preference 2 g711ulaw
codec preference 3 g711alaw
incoming called-number . <---- add this
voice-class codec 1 <---- add this
This will match the correct codec when the SIP Proxy attempts to use G729.
Peter Fiers Mon, 08/04/2008 - 05:47
thank you for answering.
There are two issues I might address:
1. The configuration you suggest results in rerouting the call to the SP. In this case there is no 488 problem, but it doesn't work either.
2. Does the line 'a=fmtp:18 annexb=yes' in the invite message from the SP not mean what you postulated above, that the parameter "annexb" be included in the SDP?
Besides, I've tried with an additional dial-peer like this:
dial-peer voice 20 voip
destination-pattern 062211879000
voice-class codec 1
session target ipv4:
But this resulted in the same 488 media incompatibility message.
And last but not least: Why does it work from fixed line phones of the german telecom? The config is the same...
