How do you set a port on Cisco 4006 to belong to VLAN 10?
Answered Question
Aug 4th, 2008
Hello Guys,
I have forwarded several ports on my 3560 to belong to VLAN 10 by issuing switchport access vlan 10 and works fine. How do you set this on Cisco 4006 box? I have tried set port vlan 10 and did not work. Please help!
Eric
Correct Answer by lee.reade about 8 years 7 months ago
If this switch is running CATOS then you use the following command;
set vlan 10 x/y
where x is module and y is port, ie 4/1, module 4 port 1.
LR
Overall Rating: 5 (1 ratings)
Correct Answer
lee.reade Mon, 08/04/2008 - 04:44
  • Silver, 250 points or more
set vlan 10 x/y
LR
Eric Boadu Mon, 08/04/2008 - 04:53
Thank you very much LR. I'm going to test this right now and get back to you.
Thx,
Eric
Eric Boadu Mon, 08/04/2008 - 05:24
Thank you LR it is working fine now. Thanks a bunch!
Eric
