Spanning-tree wireshark question
Answered Question
Aug 4th, 2008
I am seeing the following lines in Wireshark, but the priority I am seeing is that of the root bridge. Does it matter that I am seeing these wireshark captures on my access switches?
27 8.367618 Cisco_0a:ff:96 Cisco_0a:ff:96 LOOP Reply
28 10.000372 Cisco_0a:ff:96 Spanning-tree-(for-bridges)_00 STP RST. Root = 8192/00:d0:02:d5:74:15 Cost = 23 Port = 0x8016
29 12.000442 Cisco_0a:ff:96 Spanning-tree-(for-bridges)_00 STP RST. Root = 8192/00:d0:02:d5:74:15 Cost = 23 Port = 0x8016
30 14.000520 Cisco_0a:ff:96 Spanning-tree-(for-bridges)_00 STP RST. Root = 8192/00:d0:02:d5:74:15 Cost = 23 Port = 0x8016
31 16.000604 Cisco_0a:ff:96 Spanning-tree-(for-bridges)_00 STP RST. Root = 8192/00:d0:02:d5:74:15 Cost = 23 Port = 0x8016
32 18.000688 Cisco_0a:ff:96 Spanning-tree-(for-bridges)_00 STP RST. Root = 8192/00:d0:02:d5:74:15 Cost = 23 Port = 0x8016
33 18.367969 Cisco_0a:ff:96 Cisco_0a:ff:96 LOOP Reply
Correct Answer by Francois Tallet about 8 years 9 months ago
No, just because STP is running on the access ports;-) Looks perfectly normal.
Francois
Overall Rating: 4.5 (2 ratings)
massimiliano.se... Mon, 08/04/2008 - 05:35
  • Silver, 250 points or more
This is because spanning-tree is enabled on access port too.
In hope this helps.
Best regards.
Massimiliano.
Jason Fraioli Mon, 08/04/2008 - 05:43
Would these captures be the result of Portfast/BPDUguard running?
Correct Answer
Francois Tallet Mon, 08/04/2008 - 09:14
  • Gold, 750 points or more
Francois
bmbreer Mon, 08/04/2008 - 10:26
It's normal. STP is sent via a multicast MAC address so all hosts on the network will see the STP messages assuming it's not disabled for that broadcast domain.
