VPN Clients Only See Directly Conencted Network
Answered Question
Aug 4th, 2008
Hello - I have a Pix 515 that I am using for VPN. Everything works, except once connected, the clients (172.16.3.0) can only see the directly connected network (192.168.2.0), and not any of our other subnets. Whats missing?
Andy,
The ASA inside IP Subnet is 192.168.2.0/24 - but you do not have routes to indicate any other subnets of the 192.168.0.0/16 exist. if you have more subnets on the inside network, then you need to let eh ASA know about them eg:-
route inside 192.168.1.0 255.255.255.0 <>
You should also decided if you are going to tunnel all traffic, or split-tunnel.
HTH>
Overall Rating: 5 (1 ratings)
Correct Answer
Andy,
HTH>
