Error upgrading the firmware from 3.0 to ny version on WLC
Aug 4th, 2008
Hi All,
Please help me on this issue:-
I am currently running 3.0 version on my WLC 4402 and i want to upgrade it to the latest versions. I am following the correct procedure mentioned in the cisco link but its failing.
The error is TFTP Path is getting as:c:\temp\/ error and the firmware is not getting uploaded,
Plz see the snap shot and let me know what am i doing wrong.
Overall Rating: 4 (1 ratings)
krishanmistry Mon, 08/04/2008 - 13:24
change your file path, by deleting c:\temp\/ and just use /.
TFTP Path = /
Hope this helps.
usmanshariff2008 Mon, 08/04/2008 - 21:06
Hi Krishan,
TFTP Path=/ :- It takes automatically.
I have tried both ways as mentioned below
(Controller) # Transfer download path c:\temp\
But the result is same nothing happens. Kinbdly let me know why is this happening.
Thanks in advance.
krishanmistry Tue, 08/05/2008 - 01:24
I would not use c:\temp just make sure that you point your tftp server to the folder where the file is:
(Controller) # Transfer download path /
krishanmistry Tue, 08/05/2008 - 01:26
also make sure that your tftp server supports files of a 30Meg, tftpd32 is a good tftp server.
usmanshariff2008 Tue, 08/19/2008 - 00:54
Hi Kris,
Still i am facing the same problem.Now i have downloaded the tftpd32 and I tried connecting via the Service Port interface which has a different IP address. I conneced to the controller via the console cable to issue the commands but it still will not transfer. I can ping the tftp server from the Controller. I used the paths specified , ie , "." and "./" but stil the result is same.
Kindly let me know if there is any thing missing?
Thanks in advance.
Trending Topics - Security & Network
