Error upgrading the firmware from 3.0 to ny version on WLC
Aug 4th, 2008
Hi All,
Please help me on this issue:-
I am currently running 3.0 version on my WLC 4402 and i want to upgrade it to the latest versions. I am following the correct procedure mentioned in the cisco link but its failing.
The error is TFTP Path is getting as:c:\temp\/ error and the firmware is not getting uploaded,
Plz see the snap shot and let me know what am i doing wrong.
krishanmistry Mon, 08/04/2008 - 09:49
take out the file path and leave the default of /(slash). the controller will use the root tftp folder to find the image.
TFTP Path = /
usmanshariff2008 Mon, 08/04/2008 - 21:09
Hi kris,
Thanks for the info.
I am following this link itself ut as i told after i give the tftp dest download path as c:\temp after that the download failed and gives the error: c:\temp\/ (Forward slash) i am not sure why this forward slash coming into picture?
Kindly let me know if you have face something like this.
krishanmistry Tue, 08/05/2008 - 01:21
I would not include any path, as the controller would automatically include a forward slash, just make sure that the file is within the TFTP root folder.
Hope this helps
krishanmistry Tue, 08/05/2008 - 13:21
Also make sure that your TFTP server supports larger files, a recommended TFTP server is 'tftpd32'
