Unity 5
Answered Question
Aug 4th, 2008
Hi All,
I have installed Unity 5. The system work fine but i have some problem with the web admin configuration which some pages are readable as the attached file is the example of the page that cannot read. And the other attached file is the error occur when i started the unity service.
Does it have any solution to fixing the problem ?
Thanks you,
Vit
Correct Answer by thfergus about 8 years 5 months ago
From the desktop, Start>Programs>Administrative Tools> Internet Information Services Manager, expand the name of the Unity server, expand "Web Sites", expand "Default Web Site", right-click "SAWeb", and select properties. Ensure nothing is entered in the field "Application name:" on the Virtual Directory tab. If there is anything in this field, please deleted it and see if that resolves the Unity System Administration web page issues.
Concerning the error displayed in the the Unity2.jpg, is appears you were attempting to make changes to the Unity Telephony Integration Manager before the Unity services had started completely.
Overall Rating: 2 (1 ratings)
Correct Answer
thfergus Mon, 08/04/2008 - 10:32
vittawatibm Fri, 08/08/2008 - 00:10
hi sir,
I have checked the following instruction. there is nothing in that field. I thought there are some file missing in commserve --> web --> include folder. Any suguestion ?
thank you,
Vittawat.
vittawatibm Tue, 08/12/2008 - 05:56
The problem was solved. I have checked the LocalizationFiles folder and checked the content in the loc file. It didn't have content in there. So i did copy that folder from the original dvd to replaced the existing folder.
Thank you,
Vittawat
