Cisco CME Adding Didgits to the end of dialed numbers
Aug 4th, 2008
Greetings, i have a CCME setup running version 7.0, inbound and outbound calls are working as expected except that call setup for outbound calls can take anywhere from 5 - 15 seconds, ive spoken with a couple of people in regards to this issue as such one person mentioned adding "#" at the end of the number which set's up the call immediately.
Is there a way i can re-configure the existing outbound translation profile to add "#" at the end of every number sent to the SIP provider.
I do realise that the Interdigit timeout value can be decreased which is currently set for 6 seconds but the telephony users report that when the timeout is set for 2 - 3 seconds it is not enough time to dial a number...oh i despair!
Current config.
voice translation-rule 2
rule 1 /^999$/ /999/
rule 2 /^9\(.*\)$/ /\1/
voice translation-profile SIPOutbound
translate called 2
dial-peer voice 2 voip
description **Outbound call to SIP**
translation-profile outgoing SIPOutbound
preference 1
destination-pattern 9T
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
DRAGI RADOVANOVIC Mon, 08/04/2008 - 06:57
Maybe you should be more specific with your dial peers. Create some for the 7-digit dialing (destination-pattern 9[2-9]......) one for long distance (destination-pattern 91[2-9]..[2-9]......
prefix 1)
and so on.
Your 9T pattern matches everything and relies on the interdigit timeout to call out.
Dragi
