08-04-2008 07:35 AM - edited 02-21-2020 03:52 PM
I am trying to log SSL VPN access on my Cisco ASA 5520. I can only seem to log via the ASDM or my syslog server when a session ends and not when they connect. I get the Syslog ID of 113018 when they disconnect.
e.g:
113019
Error Message %PIX|ASA-4-113019: Group = group, Username = username, IP = peer_address,
Session disconnected. Session Type: type, Duration: duration, Bytes xmt:
count, Bytes rcv: count, Reason: reason
All logs: http://www.cisco.com/en/US/docs/security/asa/asa80/system/message/logmsgs.html#wp4769539
Must be a way to show when someone logs on successfully?
08-04-2008 10:54 AM
Check this :
Message %PIX|ASA-6-113012: AAA user authentication Successful: local database:
user = user
Explanation : The user associated with a IPSec or WebVPN connection has been successfully authenticated to the local user database. user is the username associated with the connection.
08-04-2008 11:32 AM
08-05-2008 08:59 AM
Andy, just following up, are you all set with your query?
Rgds
Jorge
