Rob Huffman Mon, 08/04/2008 - 07:49
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Youssef,
Only two numbers can be setup this way in CUE, the users Primary DN and the number entered in the E.164 slot (you can use this for a Mobile or other number that you frequently use to access CUE;
Place one ext in the primary ext field, and the other in the E.164 field
phonenumber - Specifies a number or extension for this user. No spaces or dashes are allowed.
phonenumberE164 - Specifies a telephone number with area code for this user. No spaces or dashes are allowed.
Example:
se-10-0-0-0(config)# username user3 create
se-10-0-0-0(config)# username user3 phonenumber 50180
se-10-0-0-0(config)# username user3 phonenumberE164 13335550180
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_administration_guide_chapter09186a00803ef7a7.html
Hope this helps!
Rob
youssef.ahmed Mon, 08/04/2008 - 08:18
Hi buffman,
What I need exactly is :
When a user from his mobile phone which is 0123205070 dials CUE he gets the same conversation when he presses messages button from his ip phone to retrieve his voicemail
Rob Huffman Mon, 08/04/2008 - 08:46
  • Hall of Fame,
    Founding Member
Hi Youssef,
If you enter the mobile # 0123205070 as the E164 number for the user this will be the expected behaviour (same as sitting at his/her desk and pressing the Message button)
se-10-0-0-0(config)# username user3 phonenumberE164 0123205070
From this good doc;
Hope this helps!
Rob
youssef.ahmed Mon, 08/04/2008 - 09:16
Thx buffman,
It seems CUE was hanging,I reloaded it & everything worked ok.
That hanging was confusing me
Thx
youssef.ahmed Tue, 08/05/2008 - 03:16
My customer needs that to be variable from any branch in his company also.
So I think translation-rule will bo more flexible.
Right?
Or does CUE new versions support more than ephonee.146 numbers
