Standby Router
Aug 4th, 2008
Is it possible to connect two routers, for redundancy purposes,with the same T1, each router having a mirror configuration. One of the routers should be actively using the T1 while the other is on standby waiting for the active to fail.
Overall Rating: 4 (1 ratings)
rkhalil Mon, 08/04/2008 - 09:02
  • Bronze, 100 points or more
You must use HSRP:
Config example:
Router A(active):
hostname RouterA
interface ethernet 0
ip address 1.0.0.2 255.255.255.0
standby 1 ip 1.0.0.1
standby 1 preempt
standby 1 priority 200
standby track serial 0
interface serial 0
ip address 4.2.2.1 255.255.255.252
Router B(stand by):
hostname RouterB
ip address 1.0.0.3 255.255.255.0
standby 1 preempt
standby 1 priority
interface serial 0
ip address 4.1.1.1 255.255.255.252
Router A and B ethernet interface must be connected in the same segment.
When Serial0 fail the router B take the control and publish the virutal ip.
For more information visite:
http://www.cisco.com/en/US/docs/internetworking/case/studies/cs009.html
Raul
(please rate helpful posts)
hipohoneywell Mon, 08/04/2008 - 10:31
Raul, your example doesn't help, because I need the routers to have the same IP address (mirror)on the Serial interfaces. A Y cable coming from the smart jack will go to both Serial ports.
Any other idea please?
