Busy no answer, a way to force it?
Aug 4th, 2008
  • Green, 3000 points or more
Is there a way to force a busy no answer if I do not have a phone built?
Example:
IPCX, customer hits a button to transfer to voicemail. Hits CUCM and a line that is built for this. Line is configured for Call Forward all, which goes to Unity and plays the standard greeting. Our goal is to play the busy no answer greeting. But kind of hard to do if I cant make the call busy on CUCM, then to unity. In Unity, I do not want to activate the Busy greeting as primary for other reason.
Am I stuck? Or is there a way on CUCM to classify that call as Busy, then to the Unity subscriber?
gthaliwal Tue, 08/05/2008 - 02:55
Maybe you could try a configuring Hunt Pilot pointing to an empty/invalid Line Group. On the Pilot set a forward busy to your VM pilot point?
