How do I determine number of licenses on my CallManager 3.3?
Answered Question
Aug 4th, 2008
How do I find the number of licenses for IP Phones, etc. currently on my CallManager 3.3? Thanks
Correct Answer by Rob Huffman about 8 years 11 months ago
Hi Paul,
In all CCM Versions prior to 5.x the licenses were "paper" only. There is no actual reference to be found via ccmadmin. If you do a search via Device>Phone>by each model type you will find the numbers to input in the License Calculator.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
r.stockton Mon, 08/04/2008 - 09:12
The licences are tied to the phone. On previous versions of CallManager, when you purchased the phone, you got the licence. Are you trying to determine your licence count for an upgrade to 6.x?
paul.m.phelps Mon, 08/04/2008 - 10:24
Isn't there a way to look on the CallManager 3.3 Administrator web interface to see how many licenses are currently on the CM?
Rob Huffman Mon, 08/04/2008 - 09:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paul,
Please find the attached License unit Calculator. This will help determine the number of phone licenses that correspond to your current number of IP Phones.
Hope this helps!
Rob
Correct Answer
Rob Huffman Mon, 08/04/2008 - 10:36
  • Hall of Fame,
    Founding Member
Hi Paul,
Hope this helps!
Rob
Rob Huffman Mon, 08/04/2008 - 11:50
  • Hall of Fame,
    Founding Member
Hi Paul,
You are most welcome my friend :) Best of luck on your upgrade.
Take care,
Rob
