Router for Channelized DS3.
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Mon, 08/04/2008 - 12:02
  • Hall of Fame,
    Founding Member
Hello Mark,
I don't see a channelized DS3 module not even for C3845
see
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8016a8e8.html
I would go for a C7204VXR that can install channelized Ds3 port-adapter
Use the following as a reference
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/multichannel_serial/channelized-t3_dual-wide_install_config/4584ct3d.html
Hope to help
Giuseppe
Giuseppe Larosa Mon, 08/04/2008 - 12:20
  • Hall of Fame,
    Founding Member
Hello Mark,
I think it is EOL a 7206VXR with NPE 400 or less processor engine.
There are NPE-G1 and NPE-G2 processor engines and they are used, we have just bought two.
See
http://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_end-of-life_notice0900aecd806b8c96.html
C7304 can be OK I haven't used it but I think it shares the PAs with 7200 so can be fine
Hope to help
Giuseppe
